Liquid Cpu cooling
Solved by javedH,
6 minutes ago, Mick Naughty said:Yes if you want. The cable on the h100i only tells the mobo how fast it's going. So you can connect it to any header. I connected my fans to the h100i. Then the pump to the CPU header. As you will have to use the USB dongle to control them via the software.
Thanx man, am going to make that change.
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
8
derekchan ·
Posted in New Builds and Planning12 -
1
2
7
5
7
play_circle_filled
Latest From ShortCircuit:
