How do Multi-GPU setsups benefit Streaming?
Solved by Xenift,
There really isn't any benefit to it.
If the source of the video output is from a console, then having 2 GPUs in SLI or XFire will not affect the quality or efficiency in which the data is streamed.
More so i think the main reason is that more of a redundancy factor, like since you are already streaming might as well get a beast ass computer so you can stream on the computer if you need to. Sorta thing.
Streamers are pretty rich
