so im using netbeans 8.2 IDE and mysql database. when i made a web application and tried to run my jsp i got 2 errors saying :
C:\Users\hp\Desktop\fashionsite\nbproject\build-impl.xml:874: The following error occurred while executing this line:
C:\Users\hp\Desktop\fashionsite\nbproject\build-impl.xml:296:
my servlet has a red exclamation mark near its icon but there is no error in it.  there were solutions from other sites saying to delete the build.xml and restart netbeans so that it will create a new build .xml file. but this did not work. i havent found any solution for what is causing this error.it would be very helpful if someone could suggest a solution.thanks
  • 2 years later...
+  unbalanced quotes in -Xbootclasspath
iam getting this anyone help!
