I'm looking for a good motherboard $100 or lower (Budget Build) to support the AMD FX 8350 i'm getting in a month or so.
*Case- Corsair Carbide CC-9011023-WW 200R Mid-Tower Gaming Case
So I will need a ATX Motherboard
Just in  case you want to know, here are the components I plan have decided to buy or get gifted (Christmas :D) :
GPU -EVGA Geforce GTX 760
CPU- AMD FX 8350 Vishera
RAM- Patriot Viper Xtreme 4GB Desktop Memory Module  X 2 = 8GB of Ram
HD- Western Digital Black Hard Drive 1TB
Disk Drive- Asus DRW-24B1ST 24X Internal DVD Burner
PSU - Corsair CX 600
Specs:  CPU- AMD FX 8320 @ 3.5Ghz Cooler: Hyper 212 Evo Motherboard: GIGABYTE GA-990FXA-UD3 GPU -EVGA GeForce GTX 970 4GB Superclocked  RAM- 16GB 1600MHz (4x4)  HD- Western Digital Blue Hard Drive 1TB  PSU - Corsair CX 750M Case: Corsair 300R OS-  Windows 7 Home Premium 64 bit Mouse: Razer Deathadder 2013 Keyboard: Razer Blackwidow Ultimate Edition 2013
https://linustechtips.com/topic/76858-motherboard-help/
Anyone?
https://linustechtips.com/topic/76858-motherboard-help/#findComment-1055443
The Asus M5A97 R2.0 is a great choice for a motherboard under $100. If you want to save some money, you can get an 8320 which is basically a lower binned and clocked 8350 but with a good cooler you will be able to overclock to match the 8350. I would switch the Caviar Black 1TB drive to a Seagate Barracuda 1TB if you don't really care about having shorter warranty as it runs cooler.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/76858-motherboard-help/#findComment-1056052
