Hey, i see you are facing a lot of problem due to high disk usage of your system that many times leads to lagging.Well i have the solution to your problem i found this link on internet..really a helping article http://errorcodespro.com/tiworker-exe-high-disk-usage-windows/. At begining i thought it was because of hard drive failure but i applied the solution it worked very well. You can find your solution at the given system.
https://linustechtips.com/topic/767667-gta-v-high-cpu-usage-help/
