Hello people,
So I've run into a problem which I'm not 100% sure how to fix. I currently have 4 gaming console connected to a HDMI switch followed by a capture card (Elgato HD60) connected to my second monitor which is fine. If the Elgato HD60 didn't have such high audio lag i would use that but its more than a few seconds so whatever game you play you'll notice it. The problem is, not all of the consoles have another audio solution like the PS4 and Xbone, which I still have to swap the optical cable between depend on which console I'm using. I was wondering if there was a 4 port HDMI switch that has a analog output so I can use a headset for both my PC and consoles.
Should I be buying a digital audio receiver or is there some other solution. The screen the consoles are plugged into do not have an analog audio pass-through either, trust me I tired.
Any feedback or help would be great ^_^
https://linustechtips.com/topic/767294-hdmi-audio-problem/
