Budget&Location:750-800$(60000INR[₹]),INDIA
PURPOSE:Gaming and Music production.
No peripherals,monitor needed.
Already got 1tb wd green Hdd.
My personal opinion  of cpu R5 1600X.
I must be able to play High-end games at 1440p or atleast 1080p on high/ultra settings. A small amout of ssd will do for basic softwares and os.
Help me build one ✌️.
My upcomming rig configuration.
CPU: AMD Ryzen 5 1600X 3.6GHz 6-Core Processor  ($248.98 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: Gigabyte GA-AB350-GAMING 3 ATX AM4 Motherboard  ($109.89 @ OutletPC)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory  ($124.88 @ OutletPC)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  ($74.99 @ Jet)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($72.88 @ OutletPC)
Total: $656.50
Generated by PCPartPicker 2017-04-16 18:33 EDT-0400
P.s-will include gpu once Rx 500 series launches till than let me know how balanced my mid-range build is..?
https://linustechtips.com/topic/766996-a-mid-range-balanced-build/
CPU: Intel Core i5-7500 3.4GHz Quad-Core Processor  (₹16745.00 @ Amazon India)
Motherboard: MSI B250I PRO Mini ITX LGA1151 Motherboard  (₹5418.68 @ Amazon India)
Memory: Crucial 8GB (2 x 4GB) DDR4-2133 Memory  (₹3759.00 @ Amazon India)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (₹3632.00 @ Amazon India)
Video Card: MSI GeForce GTX 1070 8GB Video Card  (₹25741.26 @ Amazon India)
Case: Rosewill RANGER-M MicroATX Mini Tower Case  (₹2019.39 @ Amazon India)
Power Supply: Corsair CXM 650W 80+ Bronze Certified Semi-Modular ATX Power Supply  (₹6950.00 @ Amazon India)
Total: ₹64265.33
Generated by PCPartPicker 2017-04-16 03:14 IST+0530
Total: ₹64265.33
I doubt the motherboard won't work out for me,  mini itx mob doesn't usally have a scope for future upgrade,it has only 2 memory slots and a single pcie slot. I might consider crossfire or sli in future too so. And cpu wont do good either.Don't need a hdd either.
But thanks.
But thanks.
why won't 7500 do well? please explain. SLi and CrossFire are pretty much dead unless you have INFINTE budget.
CPU: AMD Ryzen 5 1600 3.2GHz 6-Core Processor  (₹18000.00 @ Amazon India)
Motherboard: Asus PRIME B350M-A/CSM Micro ATX AM4 Motherboard  (₹8129.00 @ Amazon India)
Total: ₹64598.65
Generated by PCPartPicker 2017-04-16 03:32 IST+0530
The software used in music production demand more cpu power,  as i5 7500 doesn't support hyperthreading/multi-thread count is low..  it will be quite usless for meh.
Total: ₹64598.65
Its fine create the build in us v
ersion I will might get the reset of the parts from stores.
I might go for better memory.
