My 780 is getting terrible stutter while playing BF4 but runs smooth on everything else. My temps are good my drivers are new. IDK!!!! HELP!
Also i have ASUS 144 hz Moniter. IDK if its the reason but just trying to figure it out.
https://linustechtips.com/topic/76687-780-and-bf4-problems/
https://linustechtips.com/topic/76687-780-and-bf4-problems/#findComment-1052361
Specs? OS your using as well.
Motherboard: MSI-990FXA-GD65 | CPU: AMD FX-8350 @ 4.3Ghz | CPU Cooler: Corsair H100 | RAM: 8GB Corsair Vengeance 1600Mhz | GPU: MSI GTX 770 Lightning @ 1300Mhz CC and 8000Mhz MC | Case: Fractal Design ARC Midi R2 | PSU: Corsair AX850 | OS: Windows 8.1
https://linustechtips.com/topic/76687-780-and-bf4-problems/#findComment-1052365
https://linustechtips.com/topic/76687-780-and-bf4-problems/#findComment-1052367
Its on my sig, but i have a gtx 780 direct CUII
Sorry I am on my phone had to switch to full version view. What OS are you currently using?
https://linustechtips.com/topic/76687-780-and-bf4-problems/#findComment-1052372
Its ight thanks for the help! Im running Win 7 64bit
https://linustechtips.com/topic/76687-780-and-bf4-problems/#findComment-1052375
Try unparking your cores, it has removed the stutter for some people.
<p>Mobo - Asus P9X79 LE ----------- CPU - I7 4930K @ 4.4GHz ------ COOLER - Custom Loop ---------- GPU - R9 290X Crossfire ---------- Ram - 8GB Corsair Vengence Pro @ 1866 --- SSD - Samsung 840 Pro 128GB ------ PSU - Corsair AX 860i ----- Case - Corsair 900D
https://linustechtips.com/topic/76687-780-and-bf4-problems/#findComment-1052383
Did this problem just start for you? I'm asking because this was a known problem when the game was running on Win 7 I was having the same problems but when I switched to Windows 8.1 it helped a lot. Your specs are fine may want to search the forum for a tread called "core parking BF4"
https://linustechtips.com/topic/76687-780-and-bf4-problems/#findComment-1052384
Yah i plan to upgrade on black friday. Thanks ill check it out.
https://linustechtips.com/topic/76687-780-and-bf4-problems/#findComment-1052389
That problem was fixed after the first week of the beta. I don't think that is what the problem is although it still could be. I am running a 780 with the latest drivers and windows 7 64 bit and I have no problems other than the ones the game causes itself.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/76687-780-and-bf4-problems/#findComment-1052395
Windows 8.1 is a good upgrade regardless of the frame boost.
https://linustechtips.com/topic/76687-780-and-bf4-problems/#findComment-1052401
Its OK I do like Windows 8.1 though the BF4 improvement in fps was 30-45 fps.
https://linustechtips.com/topic/76687-780-and-bf4-problems/#findComment-1052422
Double post sry
https://linustechtips.com/topic/76687-780-and-bf4-problems/#findComment-1052423
Also i skip in game and drop frames and i freeze
This usually means your CPU cores are getting parked thus not being fully utilized, this is a power saving feature in Windows, it "parks" cores in your CPU to save power, basically puts them in an inactive state, this is all good but the issue is that it stays like that when you're playing games, i had the same issue in BF3 and after disabling it my CPU usage became stable thus eliminating frame skipping.
You can use this app called ParkControl or if you don't want to download anything, just open the windows command line (CMD) preferably with administrator rights and paste this "powercfg -setacvalueindex scheme_current sub_processor 0cc5b647-c1df-4637-891a-dec35c318583 100" without the quotes, then to make sure the settings are applied, paste this command as well "powercfg -setactive scheme_current".
The settings should take effect instantly without the need of rebooting.
Also like said before, Windows 8 is a worthy upgrade because it uses less hardware resources on your PC, plus, Battlefield 4 was developed on Windows 8 and with it in mind, simply because it's less stressful on the hardware.
“The mind of the bigot is like the pupil of the eye; the more light you pour upon it the more it will contract” -Oliver Wendell Holmes “If it can be destroyed by the truth, it deserves to be destroyed by the truth.” -Carl Sagan
https://linustechtips.com/topic/76687-780-and-bf4-problems/#findComment-1052531
Switch to Win8 and unpark cores.
My rig: CPU: Intel core i5 4670K MoBo: MSI Z87-G45 Gaming RAM: Kingston HyperX Beast 2x4GB 1600mhz CL9 GPU: EVGA GTX780 SC ACX SSD: ADATA Premier Pro SP900 256GBHDD: Western Digital RED 2TB PSU: FSP Aurum CM 750W Case: Cooler Master HAF XM OS: Windows 8 Pro
My Build log, the Snowbird (heavy WIP): http://linustechtips.com/main/topic/188011-snowbird-by-lachy/?hl=snowbird
https://linustechtips.com/topic/76687-780-and-bf4-problems/#findComment-1052643
Give the commands to undo this as well.
https://linustechtips.com/topic/76687-780-and-bf4-problems/#findComment-1078655
