Temporary fix for CS:GO sound stutters (macOS, Ubuntu, Linux)
Valve is currently reviewing this case and is working on it!!
So I was on CS:GO's macOS, Linux and Ubuntu GitHub and I saw that the sound is still glitched.
I also found a temporary fix for this.
(Type in console or your cfg)
snd_mixahead 0.1
snd_use_hrtf 0
Type this in your launch options
+snd_mixahead 0.1
+snd_use_hrtf 0
Note, now the sound will be slightly delayed and you will not be able to use HRTF but this is the temporary "stutter" fix until Valve releases the fixing update(s) (they're working on it)
Hope this helps.
when that happens, usually my screen goes black and stays black for 5 seconds
i cannot tell you how many times that happened to me mid gun battle. :/
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
That sucks, hopefully this'll fix it
its ram related i believe.. my ram is shitty
1066mhz cas10 and still somewhat unstable..
