Hello everyone,
after a 2 months hiatus away from my computer, took my computer back yesterday in the afternoon.
It's been moved a bit around, so I was wondering if some parts moved during that. So I took my beast for a test run yesterday.
After playing some games for 5-10 minutes, first BSOD. Rebooting the PC, multiple BSOD, one after one.
Error code : 0x00000124, so apparently hardware failure.
Here is the crash syslog if you are interested :
Log Name:      System
Source:        Microsoft-Windows-WHEA-Logger
Date:          13/04/2017 23:34:53
Event ID:      18
Task Category: None
Level:         Error
Keywords:
User:          LOCAL SERVICE
Computer:      MJOLNIR
Description:
A fatal hardware error has occurred.
Reported by component: Processor Core
Error Source: Machine Check Exception
Error Type: Internal Timer Error
Processor ID: 0
The details view of this entry contains further information.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Microsoft-Windows-WHEA-Logger" Guid="{C26C4F3C-3F66-4E99-8F8A-39405CFED220}" />
    <EventID>18</EventID>
    <Version>0</Version>
    <Level>2</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8000000000000000</Keywords>
    <TimeCreated SystemTime="2017-04-13T21:34:53.335626100Z" />
    <EventRecordID>180869</EventRecordID>
    <Correlation ActivityID="{547FFC19-3403-4C83-B669-936372F9014D}" />
    <Execution ProcessID="1496" ThreadID="1572" />
    <Channel>System</Channel>
    <Computer>MJOLNIR</Computer>
    <Security UserID="S-1-5-19" />
  </System>
  <EventData>
    <Data Name="ErrorSource">3</Data>
    <Data Name="ApicId">0</Data>
    <Data Name="MCABank">4</Data>
    <Data Name="MciStat">0xbe00000000800400</Data>
    <Data Name="MciAddr">0x66efe181</Data>
    <Data Name="MciMisc">0x66efe181</Data>
    <Data Name="ErrorType">5</Data>
    <Data Name="TransactionType">256</Data>
    <Data Name="Participation">256</Data>
    <Data Name="RequestType">256</Data>
    <Data Name="MemorIO">256</Data>
    <Data Name="MemHierarchyLvl">256</Data>
    <Data Name="Timeout">256</Data>
    <Data Name="OperationType">256</Data>
    <Data Name="Channel">256</Data>
    <Data Name="Length">928</Data>
    <Data Name="RawData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ata>
  </EventData>
</Event>
After doing some temperature diagnostics, I've realised that my CPU was reaching 95-100° celsius in-game.
So I told myself that my thermal paste was probably dead, since I haven't changed it for 1 year. My aircooler is a Noctua product, running pretty fine.
I've so changed my thermal paste 1hour ago. Took care to clean well the cooler plate and the cpu, then got some fresh new paste and applied a rice-size of it on the clean cpu plate.
The computer is now running fine, no more BSOD after 45minutes of various games.
My GPU temps are not reaching more than 50 degrees c on the highest game's settings.
On idle, CPU sitting around 45 degrees...
BUT my CPU is still reaching 75-80 degrees when I'm playing a game on the highest settings.
I've cleaned my PC and fans of all the dust (even the cpu aircooler is clean), I really don't know what I can do to lower my CPu temps... pls halp.
My PC configuration :
i7-4790k
Gigabyte GA-Z97x-UD5H
SLi of Gigabyte GTX 770
Noctua aircooler with 2x fans
32Gb of DDR4 RAM
https://linustechtips.com/topic/766373-cpu-temps/
10 minutes ago, Ymenoa said:
How on earth are you able to use DDR4 memory modules on a motherboard that supports DDR3?
And are you sure that Noctua aircooler(please specify its' full name, not only Noctua) is placed properly on top of the CPU?
 || CPU: Intel i5-8600K || Cooler: CoolerMaster Hyper 212X || Motherboard: Gigabyte Z370 HD3P || GPU: Gigabyte GTX 1050ti OC Windforce 4GB || Memory: 16GB Crucial DDR4 3000mhz || HDD: WD Black 500GB + Seagate Barracuda 2TB || SSD: Samsung 980 1TB || PSU: Corsair VS550 || Case: nJoy Ice Cage || Fans: Segotep Halo Ring RGB ||Monitor: 2x Dell 27" P2717H IPS Full HD || Second Monitor/TV: LG 49UJ620V UHD || Mouse: Logitech G502 || Keyboard: Logitech G810 + Royal Kludge RK84 || Speakers: Philips SPA-5300 subw + Arylic 2.1 + DIY Bookshelves w/ Dayton Audio || Headphones: HyperX Cloud Flight S ||
TO BE UPGRADED:
>> Headphones << >> Keyboard << >> HDD << >> Mouse << >> PC Case << >> Memory(another stick) << >> Graphics Card <<
https://linustechtips.com/topic/766373-cpu-temps/#findComment-9678627
