So I've been playing CSGO this morning, and every time I play, the audio is like corrupted. Every time I'm in a game the audio of the voices & the bullets are just stuttering. Does anyone else have the same problem? Btw anyways to fix this?
Check my Steam profile for games that I play. http://steamcommunity.com/id/childish_k1ll3r/
Planned Build PcPartPicker
https://linustechtips.com/topic/765856-csgo-audio-stutter/
Just now, Llamafairpwllgwyngyll said:
Check your audio drivers?
wtf is that? sorry
btw I'm using a MacBook Pro...
so yeah idk
https://linustechtips.com/topic/765856-csgo-audio-stutter/#findComment-9672773
Just now, CHILDISH_K1LL3R said:
wtf is that? sorry
so yeah idk
Not really a pro in this department. Nor any really, but I do believe these are what process the sounds of your games/activities. Try listening to music and see if that persists.
Bet you can't say my name 3 times fast.
https://linustechtips.com/topic/765856-csgo-audio-stutter/#findComment-9672776
1 minute ago, CHILDISH_K1LL3R said:
Does youtube count as a part of the "test"? If yes, then there is no problem with the audio of youtube
Well music is music. Basically I'm assuming it's something w/ CSGO's game. Try verifying game cache  https://support.steampowered.com/kb_article.php?ref=2037-QEUH-3335
https://linustechtips.com/topic/765856-csgo-audio-stutter/#findComment-9672781
2 minutes ago, Llamafairpwllgwyngyll said:
Sorry, that's as far as my knowledge goes. I don't know what else to check after that.
nvm still thx
https://linustechtips.com/topic/765856-csgo-audio-stutter/#findComment-9672884
I assume your on a mac, because after the update it's happening to everyone, so don't worry it will probably be fixed soon :)
the thread below is just other people saying the same thing.
https://steamcommunity.com/app/730/discussions/0/135514287300084408/
https://linustechtips.com/topic/765856-csgo-audio-stutter/#findComment-9673930
Yah I also heard from my friend's friend who is playing on Mac having the same issue. Thanks a lot for the link tho
https://linustechtips.com/topic/765856-csgo-audio-stutter/#findComment-9677716
