Painting some GPU bits help?
Solved by W-L,
16 hours ago, EdwardIIV said:Unfortunately, I wasn't able to find any disassembly videos in regards to this specific model of the GPU (even the GTX 1080 and 1070 models didn't have a disassembly video).
Any more suggestions, or is masking the best solution?
It looks like it may be painted or an applied decal, you can use a vinyl wrap if you want it to be removable but other than that masking off those portions and the rest of the GPU for painting is going to be the best.
