Okay so, I have been having an issue lately where my display outputs randomly die when playing games or watching a video in chrome. When this happens my monitor says no connect/display and no matter what connection I try, I can't get the display back without a hard shutdown and reboot.
Just a note: My GPU is it in the 4x slot on my mobo due to the 16x slot causing major screen glitching into BSOD.
Currently, I am doing some testing by using the balanced power plan, from high performance, and I also disabled hardware acceleration in chrome. So far no issues have popped up, but I expect them to continue. If you have any suggestions on what I should add to my testing please do let me know.
Basic Specs:
GPU: rx 470 4GB Stock Clocks
CPU: i5 6600k @ 4.4Ghz
RAM: 16GB at 2400Mhz
Motherboard: ASRock z170a-x1
https://linustechtips.com/topic/765472-display-outputs-randomly-die/
