I have a 6700k with a Notua Dh-15 cooler and my temps are great. Though I am starting to want to make my build look better. What water cooler is as silent as the noctua with the same performance if one exist. It seems to me that noctua takes the lead in all aspects but appearance
https://linustechtips.com/topic/765063-cpu-cooler/
It will be difficult to beat the performance of the NH-D15 truth be told. I would personally recommend probably the NZXT Kraken x62 as about the best 240/280mm AIO out there right now.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/765063-cpu-cooler/#findComment-9663929
In the overall picture a couple degrees hotter really isnt gonna change any performance. So I theoretically shouldn't even notice a difference besides looks right?
https://linustechtips.com/topic/765063-cpu-cooler/#findComment-9663943
Yea, the Kraken x62 is a 280mm AIO with RGB flavor. If you dont want RGB, you can get the x61, same thing just without the RGB.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/765063-cpu-cooler/#findComment-9663965
How loud is that compared to the DH-15. I run the low power adapters and my Noctua is silent. Would that create noise?
https://linustechtips.com/topic/765063-cpu-cooler/#findComment-9663974
the kraken can outperform the nh-d15, but if memory serves it's a bit louder, in part because the cooler is at an air intake/outtake and in part because a rad is more restrictive of air flow. But you should get close performance from similar noise levels
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/765063-cpu-cooler/#findComment-9664040
