13 hours ago, erzz said:
I can't seem to find any female to 2 male rgb extenders. I got one included with my motherboard but I want another one, is there anything I can do? Maybe a female to 4 male? A hub? I can't find any. I hope you can help me (Im using Mystic Light)
Some LED kits will come with extensions and splitters but they are standard SMD5050 LED connectors which are readily available.
https://www.amazon.com/LEDwholesalers-Splitter-Changing-LED-Strips/dp/B0077IPRAG/ref=sr_1_2?ie=UTF8&qid=1491957712&sr=8-2
-Moved to Modding Section-
https://linustechtips.com/topic/764915-rgb-cable-splitter/#findComment-9665998
