Hard drive failure
Go to solution Solved by Drak01112,
1 minute ago, Soup185 said:
The hard drive in my Toshiba Satellite is failing and I was wondering if there is a way to find my windows product key so I do not have to buy another. If I can manage to get it going what can I do to find it? Is there a solution here that does not involve me buying another copy of windows?
If you have windows 10 and link it to your account then you would have to simply log in with your account and it would be a-okay.
If not then you can use https://www.magicaljellybean.com/keyfinder/ , but if your license was OEM then you would need a new license
https://linustechtips.com/topic/764750-hard-drive-failure/
OS?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/764750-hard-drive-failure/#findComment-9660379
Computer specs:
CPU: Intel i5-6500
GPU: EVGA GTX 960 SSC ACX2.0+ 2GB
Motherboard: GA-Z170-HD3P VER.2
RAM: G.Skill Aegis 1x16GB 2400mhz
Case: Corsair Spec-01
Storage: 120GB Adata SP550 + 1TB HDD + 500GB HDD
Wireless card: Gigabyte GC-WB867D-I 802.11ac/BT 4.0
PSU: EVGA Supernova B2 750W
Keyboard: Razer Backwidow Ultimate Stealth Non-RGB
Mouse: Redragon Centrophorus M601
Headphones: Steelseries Artis 1
Monitors: LG 24MP59G-P 24-inch 75hz
https://linustechtips.com/topic/764750-hard-drive-failure/#findComment-9660380
So if its the copy of windows from the manufacturer I would need to buy a new license?
https://linustechtips.com/topic/764750-hard-drive-failure/#findComment-9660388
Yes if it was not Windows 10.
Edit: unless you used the same motherboard (or something)
Computer specs:
CPU: Intel i5-6500
https://linustechtips.com/topic/764750-hard-drive-failure/#findComment-9660392
Thanks for your help
NP
Computer specs:
CPU: Intel i5-6500
https://linustechtips.com/topic/764750-hard-drive-failure/#findComment-9660402
What OS?
https://linustechtips.com/topic/764750-hard-drive-failure/#findComment-9660405
Windows 8.1
You need to find the key then. 8.1 requires manual input.
https://linustechtips.com/topic/764750-hard-drive-failure/#findComment-9660448
