Hello i just finished my build with these components:
Cpu:I5 3350p
M/B:h61m-DGS
GPu:HD 6450
Ram:16 gb 2x8 kingston 1033
Psu thermaltake smart se 530w
HDD:500Gb Hitachi
First thing is that it crashes and says something about ram ,to disable caching or something  through  bios (Blue screen aproximatly after 1hour) How do i fix this?
Second thing is that amd catalyst it says  that my display driver is not responding and i can't do anything because when i open windows after 5-6 min it's freeze monitor and peripherals..
How do i fix these problems thanks (btw i have an hdmi cable from pc to monitor/tv)(sorry for bad english)
Thanks Jason
https://linustechtips.com/topic/76437-help/
Sounds like a broken ram dimm for me. Actually not much you can do except buying new ram/test it with memtest to be sure.
As of for the gpu. Do you have the newest drivers/tried it with dvi?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/76437-help/#findComment-1048637
