I hope this counts as a peripheral. I'm looking for a 60" to 72" desk. I would like if the desk also has at least 30" of depth. I would also like the desk to be white. I would also like the desk to not be prone to bending in the middle. Thanks!
https://linustechtips.com/topic/764186-desk-help/
If you have the space and tools, a sheet of melamine board and 2x4's do a lot. I use this for all of my desks, no bend and is decently cheap to make.
https://linustechtips.com/topic/764186-desk-help/#findComment-9653727
Buddy I would suggest you do your own desk. I've seen on youtube many videos about people creating their own desks for less than 30 bucks which is pretty awesome. All you'll need is one or two MDF boards (you decide the measurements for it), something to cut that board, a few nails, some wood glue and also if you don't want to use some wood to make the legs, a few metal legs and a lot of creativity.
 || CPU: Intel i5-8600K || Cooler: CoolerMaster Hyper 212X || Motherboard: Gigabyte Z370 HD3P || GPU: Gigabyte GTX 1050ti OC Windforce 4GB || Memory: 16GB Crucial DDR4 3000mhz || HDD: WD Black 500GB + Seagate Barracuda 2TB || SSD: Samsung 980 1TB || PSU: Corsair VS550 || Case: nJoy Ice Cage || Fans: Segotep Halo Ring RGB ||Monitor: 2x Dell 27" P2717H IPS Full HD || Second Monitor/TV: LG 49UJ620V UHD || Mouse: Logitech G502 || Keyboard: Logitech G810 + Royal Kludge RK84 || Speakers: Philips SPA-5300 subw + Arylic 2.1 + DIY Bookshelves w/ Dayton Audio || Headphones: HyperX Cloud Flight S ||
TO BE UPGRADED:
>> Headphones << >> Keyboard << >> HDD << >> Mouse << >> PC Case << >> Memory(another stick) << >> Graphics Card <<
https://linustechtips.com/topic/764186-desk-help/#findComment-9656029
