Help me to overlock
I want it for benchmarking & then I'm gonna go back to stock. Can you recommend me what voltage set for 4.8ghz?
That really is determined on the CPU it's self. Not every 3770K can hit 4.8 with descent voltages I would say try to hit 4.6 first and if you are at around 1.34 volts to 1.40 I would say not to try for 4.8 but if you hit 4.6 say some were in the ballpark of 1.25 through 1.30, then you have a really descent chip and you might be able to get a 4.8 OC.
When overclocking heat is your worst enemy, watch your temps at all times as if your CPU hits above 85C you can really start damaging the CPU
For an example, I have a 3570k and a 3770K. My 3570k hits 4.6 at 1.38 volts but my 3770K at 4.6 is at 1.28 voltes. I have never pushed the 3770K past that but with the right cooling solution Im sure it could do 4.8 but not all 3770K's are equal, it really just depends on if you got a good 3770K or not when overclocking.
