Just now, Demiurge said:
hey guys can you help me ? i cant seem to get the front panel audio to work  ive plugged the 9 pin hd audio lead from my case to the motherboards 4 pin front panel speaker  but it dosent seem to wrok and i cant find out where i should plug it
did you follow the motherboard and case manual?
The 4 pin speaker port isn't for the headphone jack, it's for a small speaker you can attach to the motherboard to listen for error codes in case the computer doesn't turn on.
As said above, there's a 9 pin jumper, probably labeled HD_AUDIO, AC97 or F_AUDIO or something along those lines.
i cant find it  ive looked and went according to the manual ...... all i can find for the front panel is the reset and power and stuff and the speaker port with 4 pin ..... the power and reset has 9 pins but thats about it
Which motherboard do you have?
4 minutes ago, Demiurge said:
maximus ix code
Found a manual here: http://dlcdnet.asus.com/pub/ASUS/mb/LGA1151/MAXIMUS_IX_CODE/E12313_MAXIMUS_IX_CODE_UM_V3_WEB.pdf
On page 18, you'll see a diagram of your board with the header you want marked as 24. Basically, it's in the bottom row, the leftmost one.
EDIT: More info about the header on page 40.
dude thanks so much i dont know how i didnt notice that ... nervous i guess (first time build )
