1 minute ago, Dutch-stoner said:
If you make sure you boot/start up from the drive you want to keep, you should be able to whipe the other drive, since it's just an extra drive without any "registry connections" to the main drive. (other then showing up etc)
what happens if i boot from the other drive
https://linustechtips.com/topic/759462-what-will-happen/#findComment-9598525
You'll have to install your hardware's drivers onto that copy of Windows for it to function properly, but you should still have access to those files... Etc.
GPU: XFX RX 7900 XTX
CPU: Ryzen 7 7800X3D
https://linustechtips.com/topic/759462-what-will-happen/#findComment-9598540
