Hey
A while ago, I reintalled windows 10 on a 120gig HyperX fury SSD and reformatted the 1tb drive I had at the time along with it. I made sure I installed it on the SSD, and all my windows stuff is stored on there. However, I didn't unplug my HDD during the installation as I just wanted to format it in the process, and I recently tried to boot without it plugged in. I made sure the SSD was #1 in the boot order in the BIOS but it wouldnt boot, just prompted me straight into the bios when I tried to restart. Would I need to reinstall windows on the SSD without having the harddrive plugged in? Would that fix it in any way?'
thanks
Main
CPU: i7 4790 Ram: HyperX Savage 24GB DDR3 GPU: Asus Strix GTX 960 MOBO: Asus B85 Pro Gamer SSDs: HyperX Fury 120gb, Corsair Force LX 128gb HDDs: Seagate SSHD 1tb + 1tb seagate HDD CPU Cooler: BeQuiet! Pure Rock PSU: Corsair RM650x Case: Fractal Design Define C window Case fans: 2x Corsair AF140 Quiet Ed. 140mm intake, 1x Corsair AF120 Quiet Ed. 120mm exhaust
Peripherals
Monitors: 2x Asus VN247H Keyboard: Logitech G810 Orion Spectrum Mouse: Logitech G502 Proteus Spectrum Headset: Logitech G933 Artemis Spectrum Mousepad: Steelseries QcK, Corsair MM300 XXL Cables: Corsair Premium Pro Red Sleeved Lighting: Corsair Node Pro
Laptops
HP Probook G4 440
CPU: Core i3 7100u Ram: 8gb DDR4 SSD: 256gb Sandisk X4 Pro Screen: 13.3" TN
Asus E403SA
CPU: Pentium N3700 Quad Core Ram: 4gb DDR3 SSD: 128gb eMMC Screen: 14" 1080p TN
Phone:
Samsung Galaxy S8
PSU Tier List Updated    Personal Steam Account
https://linustechtips.com/topic/758770-ssd-boot-help/
The something else is wrong. Did you accidentally knock out the SSDs cables?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/758770-ssd-boot-help/#findComment-9589819
because most likely Windows install didn't installed the bootloader on the SSD and it remained on the HDD
the 1st rule of installing Windows on a different drive than the one it was previously on - remove the other drive!!!!!!!
you could try and rebuild the bootloader with the Windows install (USB) drive
  • start Advanced Startup Options
  • open Command Prompt from Advanced Startup Options
  • type:
bootrec /rebuildbcd
could take up to 10 minutes to complete
https://linustechtips.com/topic/758770-ssd-boot-help/#findComment-9589879
  • type:
bootrec /rebuildbcd
Will look into it, thanks
Nope, double checked that :)
Main
Peripherals
Laptops
HP Probook G4 440
Asus E403SA
Phone:
Samsung Galaxy S8
https://linustechtips.com/topic/758770-ssd-boot-help/#findComment-9590142
