Hello, Today after a boot i noticed on post i was prompted that i had a CPU fan error. Which makes 0 sense because all fans are operational on my rig. After fiddling around in the bios and disabling direct monitoring by the bios of my fans and the pump associated with my H80. Then with a successful boot i noticed in corsair link that my case fans have been knocked down to 900RPM, While the H80 fans are still at their normal 1200,1300RPM. Where at the Balanced setting the case fans would normally sit around 1,000.
Another issue, is corsair link v4 is not making sense at all. Profiles for example are (Silent, Balanced and Performance) Ok, easy enough. But when i switch it from Balanced to Performance it knocks all fans down? Silent does the same (As it should) Is the control on the fans dynamic to the load of the CPU or the H80? I'm curious as I'm still new to this whole ordeal. Thanks for any help in advance! :D
https://linustechtips.com/topic/758383-cpu-fan-error-h80i-v2/
