I currently have a pair of e10c's, which will be great for next year of snowboarding considering the aux jack is designed to resist bending at a sharp angle, an unfortunate weak point of my other inears.
I'm in a bit of a pickle however. I changed around some settings in Viper4android (on a nexus 6p) and it sounds too good to justify keeping it off. But I'm also getting more static noise than normal, it might be the gain but I don't know.
80s profile: https://www.sendspace.com/file/qkx8d8
Rock profile: https://www.sendspace.com/file/ttlwiw
Stock with some slight adjustments I made: https://www.sendspace.com/file/kq5uwb
A random profile I found: https://www.sendspace.com/file/ttlwiw
I also have a question about eartips. So my ear canal is really small and it's really hard to find eartips that fit and feel comfortable. I found a dome tip that fits my right ear, but all the other tips I have don't fit my left ear (except for one which fits but isn't comfortable.)
I decided to try my flanged eartips again and noticed the sound quality is a lot more airy and loud. It doesn't feel as though it's in all the way, I don't know if that's just the way flanged eartips are or if they are too large. When I shake my head in various directions in holds in though.
Don't talk about stale memes.
https://linustechtips.com/topic/758138-best-settings-for-viper4android/
