Hi guys!
i have this mobo
I have this RAM :   RAM KINGSTON KVR13N9S8/4 4GB DDR3 1333MHZ PC3-10600
and i bought this RAM : RAM KINGSTON KVR13N9S8/4 4GB DDR3 1333MHZ PC3-10600
both ram are recognized by CPUz
Screenshot_2.png.f4a04eded043c1b8200f590932e0bd0a.pngScreenshot_3.png.150b78907b0f3e4d892aab0addb9a7ed.pngScreenshot_4.png.10526add84418d25d27d6d973aa1df7c.png
but windows are not recognizing the new one, neither BIOS..
can you help me? did i buy the wrong ram??
https://linustechtips.com/topic/757372-ram-problem/
5 minutes ago, gamwtospiti said:
right now i have both dimm pluged in and it works fine but windows and bios are recognizing only the old one dimm..only cpuz can see 8gb memory
Since the stick is not working in either slot, and the other RAM stick worked in either, the new RAM stick is at fault. It is likely that there is a faulty connection. Some of the connections are working, allowing diagnostics software such as CPU-z to read its information, but it is unable to be used by the OS. You could inspect the stick for any broken solder connections, and in some cases it is feasible to repair by cooking, although it would be best to just return it and get your money back.
https://linustechtips.com/topic/757372-ram-problem/#findComment-9575180
