I have an MSI H110M -Pro-D with an I7-7700K Processor, and Team Elite Plus 8GB 288-Pin DDR4 SDRAM DDR4 2400 (PC4 19200) Desktop Memory Model TPD48GM2400HC1601, currently no GPU(but have tested with a gpu still no psot), OK so my issue is whenever I attempt to turn on the system i get not screen flash and no post there will be a video file attached that will show the debugger leds on post attempt. the fan for the cpu cooler spins up upon boot so i am pretty sure it is not an power issue and am not sure if it is an issue with RAM compatibility or the CPU.
1befdd93352822e167ea997e260f383b.mp4
https://linustechtips.com/topic/757220-help-with-mobo-not-posting/
Sounds to me like your mobo bios isn't updated for kaby lake processors.
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
You need a skylake processor so you can boot up. Cause I'm pretty sure your motherboard doesn't have any other way to do it.
44 minutes ago, Dillonanimations said:
I kinda figured that to be the issue but if that is the case how can i update the BIOS if it won't post?
Current Build
AMD Ryzen 2600
Stock cooler
1tb SKHynix m.2
WD 1TB HDD
Phantek fans
Phanteks P400TG
Laptop
Ryzen 7 5800h
1tb Samsung m.2
1tb WD black m.2
