ok i have my big gaming rig that i use but then there is my parents imacs. i was wondering will windows home server 2012 allow me to use time machine to backup to the server? if not, what would be the alternate best?
Thanks in advance!
Mobo: Rampage 4 Extreme  RAM: 16GB (4x4) Kingston Hyper X silver 1600MhZ  CPU: Intel core I7 @4GhZ
GPU: 2x Reference Sapphire HD7970  PSU: Corsair AX1200  Case:  Coolermaster Cosmos 2
Boot Drive: Samsung 840 PRO 256GB-WIN7  HDD's: 5x WD Green 2tb CPU-Cooler: H100i
https://linustechtips.com/topic/757-pc-and-mac-serever-help/
I would use a Linux based server because it is free and runs on most equipment. The only thing I am unsure about is if you can format a hard drive partition in Linux to something Mac OS can use.
OSX can use NTFS drives
However if it's stored on the network I don't even think the drive filesystem matters
https://linustechtips.com/topic/757-pc-and-mac-serever-help/#findComment-16895
If you must use Windows Server check out this Instructable, it will tell you how to set up Samba shares on a Mac and backup
Samba is the file sharing system integrated into Windows and is supported on basically every operating system
However, if hosting any server I would use an appropriate OS (Windows Server is eehhhhh) like CentOS or RHEL
Perhaps you might also be interested in Crashplan, it's a great backup utility that does progressive automatic backups locally and on the network, and has a ton of great features
https://linustechtips.com/topic/757-pc-and-mac-serever-help/#findComment-16903
