Hey guys just wanted to get some advice regarding obs studio settings. I currently have a 50Mbps down and up on my internet and my specs are on my sig. What would you recommend if i were to stream on 720p or 1080p?
PC: CPU: Ryzen 5 5600X @ Curve optimzer -25,  Cooler: Noctua NH-D15 Chromax.Black, Motherboard: Asus Rog Strix B500-F Gaming WiFi II, GPU: Sapphire Nitro+ RX 7800XT @ Stock , RAM: G.Skill Trident Z RGB 2x16GB DDR4 3600Mhz CL18, HDD: Western Digital Caviar Black 2TB, SSD: Samsung 850 Evo 250GB | Team Group MP33 1TB NVME, Case: NZXT H7 Flow Black, PSU: NZXT C1200  I Peripherals: Keyboard: Ducky Shine 6 RGB Special Edition, Mouse: Razer Orochi V2, Headset: Philips SHP9500, Mousepad: Glorious Stealth Extended I Laptop: MSI GS63VR Stealth Pro CPU: i7-6700HQ@ 2.6ghz, GPU: GTX 1060, Memory: 16GB DDR4 2400Mhz, HDD: 1TB+128GB SSD
https://linustechtips.com/topic/756593-obs-settings/
Check out "Barnacules Nerdgasm." He has a fantastic tutorial and advice on streaming as well as recording. He talks about bitrate at some point.
https://linustechtips.com/topic/756593-obs-settings/#findComment-9566142
Thanks will check it out.
https://linustechtips.com/topic/756593-obs-settings/#findComment-9566150
Go for the following settings
Keyinterval: 2
Preset: Veryfast
Use: CBR
Profile: high
720p 60fps - Do downscaling on the GPU!!!!!! as your CPU is dont have multithreading and will DIE if doing downscaling on the CPU
6000kbit bitrate (yes twitch now allows 6000kbit)
That's it
https://linustechtips.com/topic/756593-obs-settings/#findComment-9570396
  • 2 weeks later...
Keyinterval: 2
Preset: Veryfast
Use: CBR
Profile: high
That's it
How do I do downscale using the GPU on obs studio settings?
https://linustechtips.com/topic/756593-obs-settings/#findComment-9631050
