10 minutes ago, Rulzz said:
my pc config is "
i7 7700k.....
gigabyte z170 gaming 7....
16GB single stick 3000bus.....
 sapphire nitro RX 470 8gb........."
what should i upgrade and upgrade to what.........???...........>>> thanks in advance :)
If the gpu is used for your rendering, get a 1080(Ti) or 1070.
5 minutes ago, Rulzz said:
and the software i use like :
3d max, Lumion, Blender, Keyshot,  Cinema 4D.....  .
most of the SW you listed either uses CUDA or OpenGL; except Keyshot (CPU only from what I found)
for that money, get another 16GB or RAM (same model number) and a nVidia GTX card ; you could sell the RX470 and that could also help you towards a new video card - GTX1070 if you can
53 minutes ago, Rulzz said:
will a gtx 1060 help ..........???
It would do the job in a stretch, but getting a 1070 will really help with your projects.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
