Hey everyone, I was just into some fans suggestion for my new NZXT 810 case I ordered. So, this is my system:
I am looking for some red or black and red kinda look fans. Fans that don't only look good but perform good as well since I really care about looking and performance at the same time as you see on my system. I am using some NZXT leds sleeve but would be fine if you guys suggest some as well. Thanks.
P.S:
I run on dual GTX 770's overclocked @ 1280MHz and they perform @ 69C and 64C as shown on the video on a load. More space on the NZXT 810 would lead to lower temps if I get to find better fans than my current cooler masters from 2011.
2020:AMD Ryzen 3900X | XFX 5700XT | 2TB m.2 | 32GBDDR4 @ 3200MHz | Corsair CX750M | ASUS X570 Strix | NZXT H100
2013:AMD FX-8350 @ 4.62GHz ~ 5.2GHz | XFX R9 290X 2x Crossfire | (x4) 2TB HDDs in RAID1 | 16GBDDR3 @ 1866MHz | GS800 | NZXT 810
https://linustechtips.com/topic/75540-performance-components-for-my-system/
Corsair fans are great
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
Any specific model?
Any specific model?
well SP for Static pressure (for places like radiators and heatsinks, tight spots.)
AF for Airflow (Moves alot of air, Perfect for exhaust and intake, any place you wanna move alot of air)
Hope I could help!
off topic question why is the video title stating a 410 instead of an 810?
Because I ordered a 810 and it's arriving in two more days. Im kinda upgrading my system and need better air cooling solutions. Thanks for asking thou
Be quiet silent wings.
They kick the shit out of Corsair fans and are quieter.
They look NICE... I have a question, is it possible for me to get the noctua d-14 whatever the name is fans? I kinda like that light brown color. If I get those fans, I'll get some white leds.
NDH14 fans are available for purchase, just check their website for which one you want. If you mean if you can use the be quiet fans on it, I'm pretty sure they the NDH14 includes mounting hardware for other fans.
Error: 410
Now, I was more into looking for a LED bar or led sleeves other than the NZXT leds... Do you know something that would be bright? or just a bar that can go on the bottom of the case?
Logisys makes some 12 inch LED sticks, if you buy those just make sure they don't have an inverter box attached.
Error: 410
