Well, as the title suggests, my problem is simple. I've observed that when on battery, the GPU performs..well...not up to the mark. CS:GO, for example, performs quite worse than when being plugged in. Well, i know that the GPU throttles down to conserve power, but the GPU is the 940MX (4GB DDR3), and I don't think that is is that power-hungry.
When plugged in, CS:GO returns a smooth 60FPS @ High/Vhigh at 1366x768 (native resolution of the Laptop) but when removing the charger reduces the frames by 20-25. Also, the integrated HD 630 (I5-7200U) don't spit out a perfect 60 at lowest setting (I honestly have no idea about its capabilities, but I think it can)
Any valuable suggestions are welcome, and thanks in advance!
Specs of the laptop:
I5 7200U CPU
GeForce 940MX 4GB DDR3 GPU
16 GB DDR4 2133MHz RAM
2TB HDD
Ryzen 5 9600x | Asrock 9060XT 16GB OC | Gigabyte B850M Gaming X WIFI32GB DDR5-5200 | SDEJava & Golang
anyone got a spare job here?
https://linustechtips.com/topic/755038-low-performance-on-battery-power/
By default your gpu will limit fps to 30 in all games on battery power. This can be changed in Nvidia control panel.
qυoтe мe pleaѕe!
Me at the Apple store: "So how fast is this little macbook?"
Apple employee: "Cheetah Fast. Lightning Fast. It's Really, really, fast."
Well, I'll check that.
But what if I want to use the integrated GPU instead?(To conserve battery, of course) what could be the optimal settings?
