PPT not saving! HELP!
Solved by DrMikeNZ,
Just now, Mikeak172 said:It unfortunately isn't a single slide issue. I have about 10 slides, one after another, with +35 "Objects" each. I wonder if ppt can only handle so many objects before just kicking the bucket. I am moving each slide over as a picture ( right click > paste > picture rather than "keep source format" ) to see if that helps
There are many different ways PowerPoint stores objects, and I can imagine too much complex data would eventually cause it to fail, and is likely the cause here. Converting to picture should get around this problem.
Can you save those other slides individually?
Share
Followers
2
