Cherry MX replacement keys question
Go to solution Solved by Spuriae,
If you're talking about the keycaps, then yes. If you're talking about the switches, be prepared to solder unless you have a modular board.
For the keycaps, you may want to consider the profile and backlighting compatibility, but they should fit.
