Hello. I am new to PC building. I just finished building my first gaming rig. I was just wondering how case fan works? My case has 2 120mm fans in it (front and back) then i decided to add 2 more 120mm fans i bought 2 cheap fans (DeepCool 120L/R) then i noticed that the cheap ones are blowing air inside my case at a more powerful rate compared to the stock one in my case. My question is how do case fan work? are they suppose to blow in are or out? Also from what i've learned the front fans should be the one blowing air inside then the top and the rear should exhaust them. How will i know if the fan is blowing air or exhausting air ?
Below is my current setup:
CPU
    Intel Processor @ 3.50GHz
RAM
    16.0GB
Motherboard
    MSI B250M GAMING PRO (MS-7A65) (U3E1)    41 °C
Graphics
    ASUS VC239 (1920x1080@60Hz)
    NVIDIA GeForce GTX 1070 (Gigabyte)    45 °C
Storage
    232GB Samsung SSD 850 EVO M.2 250GB (SSD)    43 °C
    931GB Western Digital WDC WD10EZEX-75WN4A0 (SATA)    38 °C
Thanks! :D
https://linustechtips.com/topic/754363-case-fan-tutorial-for-a-newbie-pc-builder/
CPU
RAM
    16.0GB
Motherboard
Graphics
Storage
Thanks! :D
There should be an arrow showing which way air is going. Or just feel it with your hand cause that works too.
Can put your hand in front of and behind the fan to see in which direction it's blowing.
I've also noticed that the side with the four structural linkages holding the motor usually is the exhaust side.
Which direction to blow depends on who you ask. Some swear on all exhaust, to keep dust out(?), others say to keep a fine airflow. Personally I believe in the airflow part.
Excuse my broken keyboard
CPU - Ryzen 7 2700x
GPU - RX Vega 64
SSD - Samsung 970 M.2 500GB
HDD - WD Black 4TB
Mobo - Asus ROG Strix X470-F Gaming
RAM - 32GB Corsair Vengeance DDR4
PSU - Corsair RM1000x
yes i did feel it in my hands how ever i cant tell. Particularly the stocks ones. The Deepcool fans seem to blow air inside they is quite powerful. However the 2 stock ones i really cant tell :(
Yes i've seen the linkages. All of them are  currently positioned at the back of each fan facing outward.
Are they all connected to your mobo?
CPU - Ryzen 7 2700x
GPU - RX Vega 64
HDD - WD Black 4TB
sorry, the linkeges of the 2 fans in the front are faing inward.
only the 2 fans are currently connected to the mother board. The stock ones from the case.
The side with the plastic struts is the exhaust.
Here are good places to start.
@WoodenMarker, you forgot
One from JayzTwoCents is also good:
@XBeater, could you specify which CPU and if you are using stock or aftermarket cooler? Since case fans operating was already covered, I'll answer the parts not covered. You should use some balanced setup for fans. Like shown in above video, 2 front in, 1 rear out is good general setup. Case fans can be used as intake or exhaust, and it matter only a bit if you use more powerful as intakes or exhausts. Like you suspected, having more powerful ones as intake is better.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
