so im looking for the best possible case for an extreme liquid set up and i came across the phanteks primo xl mini i would like to see what others think of the case and if they have seen a better one for liquid cooling.
LINK - http://www.phanteks.com/Enthoo-MiniXL.html
CPU-I7 4790
COOLER-Be Quiet Pure Rock Slim
MOBO-Gigabyte Z97 HD3
RAM-8GB G.skill Ripjaws X
GPU-Gigabyte GTX 1060 6GB G1 Gaming
SSD-Kingston SSDnow 240GB
HDD-Segate Barracuda 1TB
PSU-Zalman ZM 550w Goldrock Semi-Modular psu
CHASSIS-ThermalTake Core X31
https://linustechtips.com/topic/753520-most-extreme-small-form-factor-case/
Look through this article. Might help in finding things.
http://www.pcgamer.com/the-best-mini-itx-pc-cases/
Community Standards
"Beast Mode"
Dedicated Streaming Rig
those dont really have the same liquid support im looking for
CPU-I7 4790
Well, what exactly are you looking to do?
Community Standards
"Beast Mode"
a small form factor case that has extensive water cooling support such as the case i stated
CPU-I7 4790
Extensive is a subjective word, especially in SFF chassis. What are you wanting to water cool.. CPU. CPU/GPU... Everything under the sun??? Need to be better at articulating what your goals are for us to provide good, proper help on locating what you need.
Community Standards
"Beast Mode"
gpu cpu but rads galore (support for 5)
CPU-I7 4790
Well for SFF, I can promise you that you wont get anything with support for 5 Radiators.. thats for sure. You will need a full tower to get that support.
Community Standards
"Beast Mode"
not sff, itx cases.
CPU-I7 4790
not sff, itx cases.
Even ITX, the most you would likely get on a normal ITX case would be 240 front, maybe 240 top and maybe 120 rear if you are lucky.... No way you will get 5 radiators in that....
Community Standards
"Beast Mode"
well the mini xl has good rad support just wondering if anyone has seen a case with similar support for rads.
CPU-I7 4790
I've heard of the nano s being pretty good for water cooling as an itx case as it has a lot of mounting in the front and the top. Might want to check it out.
The only reason I'm here is that I have homework that I don't want to do
PC  Specs   CPU: Intel Celeron N3060 |GPU: Intel HD graphics 400 |RAM2 gigs  |STORAGE16 gigs
It took me half an hour to find where to change my signature :(
yea ive looked into the nano but i think because no one has seen anything like the enthoo xl im sold on it
CPU-I7 4790
  • 3 months later...
Today i have sharing with you 10 Best Mini ITX Cases or Gaming PC Cases To Buy in 2017. that will be fit your small space and at the same time is easy to carry. If you are interested or more some information about this to check this site...
