Help! Bottlenecking... CPU or GPU.
Go to solution Solved by Skiiwee29,
Yes, the i5 6500 will provide a leap and bounds better experience over the older FX 6300 chip. And yes, the CPU is your bottleneck.
So I'm trying to find out what I should upgrade. but i'm not sure what would improve the performance.
I think its the CPU that bottlenecking the GPU But that's only a my guess. I don't fully understand bottlenecking yet. My plan was to get these.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor
MB: MSI B150 PC Mate ATX LGA1151 Motherboard
RAM: G.Skill Aegis 8GB (1 x 8GB) DDR4-2400 Memory
Do you think that could work and if not that what would be better.
If you need more info let me know.
https://linustechtips.com/topic/753518-help-bottlenecking-cpu-or-gpu/
I think its the CPU But that's only a my guess. My plan was to get these.
most provably is a cpu bottleneck. wait for ryzen 5 and buy a new cpu motherboard and memory
Community Standards
"Beast Mode"
Dedicated Streaming Rig
