hi I need help looking for a mini itx case that would fit inside a pelican 1510 http://www.pelican.com/us/en/pro/product/watertight-protector-hard-cases/medium-case/carry-on-case/1510/
I need it to be able to support something like a gtx 1070 minihttp://www.ncix.com/detail/gigabyte-geforce-gtx-1070-1746mhz-96-134438.htm
in need this for a portable workstation.
PC specs: Ryzen 7 1700 3.9GHZ OC, 16GB DDR4 3200MHz (running at 3066MHz),GTX 1080x2  (2050MHz core) https://ca.pcpartpicker.com/list/LNmtd6 ,  1. Laptop specs: i7 6700hq, 16GB DDR4 @2400MHz, GTX 1060 (MSI GS43VR 6RE Phantom Pro)
https://linustechtips.com/topic/753066-need-help-looking-for-mini-itx-case/
I think the M1 will be too big, so A4-SFX seems to be the choice, you can also fit a fullsize GPU inside it. There might be other smaller cases, but those are the two that always comes to mind.
https://www.ncases.com/
https://www.dan-cases.com/dana4.php
