I have an Intel i5-6500 Quad Core (3.20GHz) cpu, I have two monitors and on the one, I have task manager pulled up and even in games like rocket league, my cpu is maxed out 95-100%. My friends that bought a prebuilt system for $500 and doesn't compare to my build but yet he said he gets 50% cpu in rocket league so there has to be a problem with my cpu. I have no clue though.
I did unpark my cpu awhile ago but nothing happened to it. This problem just started to be a big deal to the point of noticing just recently.
Like in Rocket league, the cpu usage is about 60% and the next highest program running is 5%, then the next is 3%, then 2% so all of it doesn't add up to 100% but I still reach it and then my system lags behind.
I have water cooling to my cpu. My gpu is a GTX 960 2GB.
The below image is at the main menu and just running in the background
https://linustechtips.com/topic/752912-high-cpu-help/
Rocket League is only half of your CPU Usage
https://linustechtips.com/topic/752912-high-cpu-help/#findComment-9526068
2 minutes ago, HubbaBubba said:
so i still dont know what to do
i would download malware bytes and spybot search and destroy those are 2 free malware removal softwares, make sure you update them and scan your system...i think you have some trash.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/752912-high-cpu-help/#findComment-9526100
Those 2 cmd processes look suspicious, do you know what it's for?
https://linustechtips.com/topic/752912-high-cpu-help/#findComment-9526135
5 minutes ago, HubbaBubba said:
I honestly dont even know what cmd mean and what they are for
Then install and run Malwarebytes like Nanosuit suggested.
While you at it can you open command prompt and type this for me?
wmic process list > C:\process_list.txt
Then attach/upload the text file process_list.txt it generated in your C: drive.
https://linustechtips.com/topic/752912-high-cpu-help/#findComment-9526178
