Changing code style in Jetbrains Webstorm
Solved by madknight3,
You can change a bunch of things, like the theme, in the settings (found under File -> Settings)
For complete IDE themes it's under "Appearance & Behavior -> Appearance"
For editor only, it's under "Editor -> Colors & Fonts"
If one of the included themes doesn't work for you, you can find and download them online.
- Color-Themes
- Jetbrains Plugins (search for theme and you'll see a few there)
- Google (as always)
As far as I know, themes that work for one Jetbrains IDE work for the rest too. So if you happen to find something labelled for IntelliJ or PhpStorm or whatever, it'll probably also work in WebStorm.
