I need help deciding whether i should build a new computer or upgrade my current one. My current computer is this: https://pcpartpicker.com/list/VscGNN. Mind you i only use this computer for strictly gaming and some schoolwork. So is it worth just upgrading the Graphics Card and throwing some ram in? Or just building a new one?
https://linustechtips.com/topic/752665-help-deciding/
Upgrade your current one:
  1. Get more RAM
  2. Get an RX 480 or a GTX 1060/1070
  3. Get a 4790K if you want
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/752665-help-deciding/#findComment-9523387
Upgrade ram, then gpu (ram will help with multi tasking, possibly More gaming fps, More chrome tabs)
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/752665-help-deciding/#findComment-9523393
Especially in games like BF1 ;)
https://linustechtips.com/topic/752665-help-deciding/#findComment-9523403
just buy a new gpu...u can go as far as gtx1070..a 1080 maybe bottlenecked by the cpu but most likely will be fine. u dont really need to upgrade ram..8gb is fine for games. upgrade the cpu/mobo/ram  in a year or two
https://linustechtips.com/topic/752665-help-deciding/#findComment-9523574
