Stream to twitch using mobile data?
Go to solution Solved by tt2468,
3 hours ago, magicammo said:
i checked that too the latency was at 50 but they werent throttling my data I was using like 100gb a month no throttle so i dont have to worry about that. the latency isnt too bad only about 30ms more than my home connection.
Not only the latency, but also the fact that 4g/mobile data is INCREDIBLY unstable connection wise. Just because a speed test says you get 5mbps, doesn't mean that it is a good connection.
I've been wanting to stream games to twitch but my home internet is wayyy too slow, but my mobile connection is a lot faster upload wise Ive tried streaming before using my mobile connection but when i did I got a lot of lag while playing online titles. My pc is fine and built to stream and the connection speed on my phone is 8 down and 5 up which is more than enough to stream 720p. anyone have any ideas on what the issue could be? I was gonna try and stream via ps4 to see if it made a difference.
CPU: AMD Ryzen 9 5900HX GPU: AMD RX 6800M RAM: 16GB  SSD: 500GB NVME
https://linustechtips.com/topic/752426-stream-to-twitch-using-mobile-data/
The issue is going to be your latency first and foremost, but your phone carrier is also going to start throttling you as soon as they see high amounts of constant bandwidth consumption.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
it doesn't matter if you have a high bandwidth cap, the telephone providers don't take nicely to you eating all of your allotted upload constantly.
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
My native language is C++
