i'm building a new PC that will feature:
CPU : i5 7500
Mobo: Msi Mortar b250m
Ram : Hyper X Fury 8gb 2400mhz
Storage: WD 1Tb Blue +SSD
Gpu : GTX 1060 6gb or RX480 8gb
As is my first build , I need some advices about PSU , I was thinking to EVGA 600 watts entry level , Corsair VS 550 , be quiet! System Power 500w,
Any advice is welcome!
https://linustechtips.com/topic/751794-psu-advice/
my advice. buy the most expensive PSU you can afford. not only is it the heart of you pc you can use the same one through countless builds. ive been an enthusiast level builder for about 12 years, im only on my second PSU!! but ive had 7 processors and 8 gpus in that time :ph34r:
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
https://linustechtips.com/topic/751794-psu-advice/#findComment-9513403
