Hi guys!
Just making sure, can you guys tell me if this PC build will work???
Here are the details:
CPU: i5 7500
GPU: Asus STRIX 1060 6GB
Motherboard: Asus Prime B250M-K
RAM: 2x8gb Crucial Ballistix Sport 2400mhz
Case: Zalman Z3 plus
PSU: Zalman ZM600(600W)
SSD: MX300 275gb
HDD: 500gb HDD (Free from a friend)
Normal LG optical drive and Windows 10 OS.
Tell me any useful tips etc, please and if it will be compatible or not... Thanks :D <3
https://linustechtips.com/topic/750669-will-this-build-work/
18 minutes ago, Toobius said:
Hi guys!
CPU: i5 7500
SSD: MX300 275gb
Different PSU, that one is not very good. Otherwise the rest is good. That case may not have the best cable management options. I just built in a similar case, the Z1 for my in-laws and was not easy getting the cables to sit properly even with flat, ribbon style cables.
I would recommend this one as its fairly cheap and a great quality: https://www.newegg.com/Product/Product.aspx?item=N82E16817151096
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/750669-will-this-build-work/#findComment-9501557
The cpu is on the motherboard's support list, so you won't need a bios update and you ram is ddr4, so you're all good.... There are two versions of that zalman-psu, but as far as I can see they both have the right connections.
I also don't know is the  MX300 SSD is the normal version or the m.2, but both will work in this motherboard. However, if you're only planing on gaming, then save the money and go for the normal ssd.
i7 7700K @ 4.8 Ghz (Kraken x52 aio cooler)
EVGA GTX 980 SC
Gigabyte GA-Z270XP-SLI Motherboard
EVGA SuperNOVA 750W G2 Power Suply
Phanteks Eclipse P400
Acer 144 hz monitor
https://linustechtips.com/topic/750669-will-this-build-work/#findComment-9501562
As he says, this setup will work, bot the brands of the psu and case is not "top quality". I don't know the prices of cases and psu's in your aera, but you can ussually get cheap and pretty brand products from a normal internet dealer.
EVGA GTX 980 SC
Acer 144 hz monitor
https://linustechtips.com/topic/750669-will-this-build-work/#findComment-9501567
Wrong section please post in  not Build Logs
IntelCorei54670k,Maximus VI Formula,Swift tech H220, 16gigs Corsair Dominator platinums, Asus DCUII GTX 780,1x256 840 evo, 1x 2TB Segate barracuda, Corsair AX 860,
3 X Noctua NF-F12, 2x Noctua NF A-14, Ducky Shine 3 Blue Leds Blue switches, Razer Death Adder 2012, Corsair vengence 1400
https://linustechtips.com/topic/750669-will-this-build-work/#findComment-9501724
