Normal 6700k temps???
Go to solution Solved by Imakuni,
Just now, robinhood22 said:
i think so what should i put it on...my mobo is z170a asus
Depends... 1.25v should be a good start. Actually, you can probably live with even less than that, but this would be a nice point to begin with.
i was rendering a video on Sony Vegas Pro 13 and I was getting 79 degrees temperature on my CPU Intel i7 6700 K and I started getting worried about the cooler not cooling well. I have a Corsair h100i V2 and my temperatures are going up to 79 degrees. and I started wondering if I had to reapply the thermal paste. is it normal to have temperatures like that or is there an actual problem? I'm not really overclocking but I do have XMP enabled and it's going up to 4.4 gigahertz other than that everything looks normal de color seems like it's in place and the fans are working just fine if you guys know anything about this please let me know
My PC is a fast boyo:
6700K - 32GB - 1080 - 256GB EVO
^^You don't need more info than this right?^^
https://linustechtips.com/topic/749896-normal-6700k-temps/
Shouldn't go that high. Make sure the pump is working and that the cooler is properly seated.
Mine is overclocked to 4.6GHz with NH-D15 and I barely go over 70 degrees Celsius.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/749896-normal-6700k-temps/#findComment-9493086
Are your voltages on Auto? If so, that could be your problem right there.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/749896-normal-6700k-temps/#findComment-9493100
https://linustechtips.com/topic/749896-normal-6700k-temps/#findComment-9493106
https://linustechtips.com/topic/749896-normal-6700k-temps/#findComment-9493115
what about my xmp setting
https://linustechtips.com/topic/749896-normal-6700k-temps/#findComment-9493119
What's your ambient temps?
If your starting out with a 30c or 35c ambient temp, you will get higher temps when compared to others.  If you are in a 20c room, well, you get the point.  The delta between ambient and core temp is what you should look at.
https://linustechtips.com/topic/749896-normal-6700k-temps/#findComment-9493120
my room is around 17-20 c its in the basement its very good chill temps
https://linustechtips.com/topic/749896-normal-6700k-temps/#findComment-9493125
That's for RAM OCing and has nothing to do with core temps. Just leave it on and forget about it.
https://linustechtips.com/topic/749896-normal-6700k-temps/#findComment-9493127
2 minutes ago, done12many2 said:
I'm sure that @Imakuni is going to have you all fixed up in no time.  I'll go about my business so as to not impede progress.  Good luck.
Guys guys guys i was on auto 1.4 volts looooooooool...i forgot to turn it down after temporarly ocing to 4.8ghz
https://linustechtips.com/topic/749896-normal-6700k-temps/#findComment-9493153
Before or after deciding so Ryzen don't make it look so bad?
https://linustechtips.com/topic/749896-normal-6700k-temps/#findComment-9494655
