Just use the water for the test then add the color
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/749741-leak-test/#findComment-9491074
make sure everything is mildly protected with paper towels or something absorbent which also help see the water and make sure you have a way to quickly turn off the system if a leak arises and just run the system with distilled water watch carefully for at least 20 minutes or so but longer never hurts and is probably better
https://linustechtips.com/topic/749741-leak-test/#findComment-9491077
20 minutes ago, smiles rising said:
when leak testing, do i use the distilled water mixed with the pastel color or do i leak test first with distilled water and then just pour the color into the reservoar? or how do i do?
I use use the fluid i normally use, Just make sure that there is no power to your system only to your pump and you'll be ok even if it leaks.  In the case of a leak just make sure you let everything dry for a good long time (like a week + for good measure).  Think It was on here a guy got into an accident with his pc's in the car and they were literally submerged in muddy water and the majority of the systems parts still worked after wards.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/749741-leak-test/#findComment-9491155
i have a spare PSU that im going to use for everything.. i also got a 24 pin thing with a "clip" on it that im going to use..
Watches and computers
https://linustechtips.com/topic/749741-leak-test/#findComment-9491167
should i mount everything before the leak test or should i do that out of the case?
https://linustechtips.com/topic/749741-leak-test/#findComment-9491171
4 minutes ago, jamesc639 said:
mount everything that will be liquid cooled and mount at least enough for it to post if you were to not then mounting after could cause a possible new leak to arise from moving everything around refitting things etc
okay :)
https://linustechtips.com/topic/749741-leak-test/#findComment-9491234
i dont need to plug in fans and such right? i only need to power the pump itself?
https://linustechtips.com/topic/749741-leak-test/#findComment-9491362
Just put everying together as intended. On fresh builds I start the pc like normal if it has enough fluid by that point. Then just get into windows and start benchmarking. That way its worse case scenario. Distilled water won't do anything if it leaks assuming it's fresh. Putting something down would make it easier to notice though. I don't as I feel it's a waste. Even mthough very first time making a custom  loop. I always add the color or inhibitor after. I normally leave room in the res for it.
https://linustechtips.com/topic/749741-leak-test/#findComment-9492450
alright :) quick question. about distilled water.. its the same as battery water right? or is there a difference
https://linustechtips.com/topic/749741-leak-test/#findComment-9492533
It's gonna be the same as what's sold in the store and what you would use, yes. Not the exact same as what would come in it, but as close as you can get.
https://linustechtips.com/topic/749741-leak-test/#findComment-9492550
i have some of this https://www.inet.se/produkt/5322418/vatska-alphacool-ultrapure-water-destillerat-vatten-1l#specs
and some of this https://www.jula.se/catalog/bil-och-garage/biltillbehor/bilbatterier-och-tillbehor/batterivatten/batterivatten-001129/
could i mix these two or is it a nono?
https://linustechtips.com/topic/749741-leak-test/#findComment-9492555
Can't read any of it so I couldn't say. Normally companies like alpha cool have premixed. Which could be diluted. Not sure how hard I try is to get distilled water where you are at. Pharmacies or decent grocery stores tend to have it. 89¢ for a gallon here.
If the ocool has something in it, companies say not to mix it with thier coolant. Just FYI. Never had any issue myself though.
https://linustechtips.com/topic/749741-leak-test/#findComment-9492682
the alphacool says something like "very clean distilled water without any additives, up to 100 times less filth than in regular distilled water thanks to a 5 step filter technique" and the other just says "destilled water"
https://linustechtips.com/topic/749741-leak-test/#findComment-9492739
Then go for it.
https://linustechtips.com/topic/749741-leak-test/#findComment-9492750
