HI what I need help with is I was wondering would I need to upgrade my motherboard at all if I took out my current graphic card which is
NVIDIA GeForce GTX 770 and put in a
NVIDIA GeForce Titan X Pascal 12GB GDDR5X or no also my power supply is 750 corsair and here is the rest of my computer CPU-Z computer info
I plan on upgrading my current CPU with
Intel Core i7-4790K Processor
tx for helping if u can not a rush right now
CPU-Z computer info
https://linustechtips.com/topic/748586-need-help/
Yes. The graphics carde really doesn't  have anything to do with the motherboard....
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/748586-need-help/#findComment-9478650
