I have a unique situation. I work in a secure facility for the Air Force and have severe restrictions on the audio equipment I can have in the building, I am also Cheap and primarily listen to audio books at work.
Imposed Requirements:
No microphones
No Active noise canceling
No internal processing
No internal memory
No wireless connectivity
No Bluetooth
No Radio of any kind
My requirements:
Over the ear headphones
I would like replaceable cords
I would like replaceable ear cups
I would like closed headphones, I know that open headphones give a better sound stage but work is noisy sometimes
Also Cheep would be nice
Thanks all, I know that you guys know way more than I do and hope you can help.
https://linustechtips.com/topic/748582-unique-situation-needs-headphone-advice/
I'm not 100% sure whether the ear cups of these are replaceable, but you could look at the audio technica ath-m50x.  Those are reasonably priced, closed back and have replaceable cables.  The other thing you need to consider is what your source is, if you're in a secure area I'm guessing you can't have your phone so what are you intending to use to play your audio books?
I would stay away from the M50x because they are uncomfortable, bit muddy mids, bad highs and the headband and pads gets worn out fast.
A budget would be nice to know, but some cheap headphones with good isolation and a fairly balanced sound would be the nvx xpt100. They got remove able pads and cable and I think you get two different pads with it.
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
