I know there are mixers that can control audio from other inputs, but is there a physical mixer that can control things from the Windows Volume Mixer? It's troublesome to tab out of games every time I want to play with audio levels slightly and am curious if there is such a mixer or if it's even called so.
Thanks in advance ^.^
https://linustechtips.com/topic/748495-sound-mixer/
You would pretty much have to get a multiple output soundcard, map each program to one output each, feed that into a regular mixer, and then feed that signal back into your headphones / speakers post mix.
It can theoretically be done but we're talking a lot of money in getting the hardware needed, plus Windows is really shit when it comes to using separate outputs. I know that some programs (media players mostly) allow you to choose what output to use but it's a huge hassle. There are also programs like Virtual Audio Cable that can split up the audio and map to separate outputs.
Reviews: JBL J33i   M50s   SRH440   Soundmagic PL50
https://linustechtips.com/topic/748495-sound-mixer/#findComment-9477716
1 minute ago, Yamanox said:
that's unfortunate...
I do believe digital mixers could do this, but those will cost you > 500 dollar at the minimum.
That time I saved Linus' WiFi pass from appearing on YouTube:
A sudden Linus re-appears : http://linustechtips.com/main/topic/390793-important-dailymotion-account-still-active/
https://linustechtips.com/topic/748495-sound-mixer/#findComment-9477727
None that actually interface fully with windows. Some are able to be used as a large array of additional I/O, but you won't be able to map different  programs to different channels, mix them and then feed them back to the computer or to a mix.
https://linustechtips.com/topic/748495-sound-mixer/#findComment-9477799
you might be able to make something yourself like an USB controller. will require quite a lot of handywork tho. (but also very interesting)
 ______     ______     ______     ______     __  __     __   __     ______     __   __     ______     ______
/\  __ \   /\  == \   /\  __ \   /\  ___\   /\ \_\ \   /\ "-.\ \   /\  ___\   /\ "-.\ \   /\  ___\   /\__  _\
\ \  __ \  \ \  __<   \ \  __ \  \ \ \____  \ \  __ \  \ \ \-.  \  \ \  __\   \ \ \-.  \  \ \  __\   \/_/\ \/
 \ \_\ \_\  \ \_\ \_\  \ \_\ \_\  \ \_____\  \ \_\ \_\  \ \_\\"\_\  \ \_____\  \ \_\\"\_\  \ \_____\    \ \_\
  \/_/\/_/   \/_/ /_/   \/_/\/_/   \/_____/   \/_/\/_/   \/_/ \/_/   \/_____/   \/_/ \/_/   \/_____/     \/_/
https://linustechtips.com/topic/748495-sound-mixer/#findComment-9480439
