Hello,
Does anyone know a good source that shows the respective charging distances for different interfaces such as USB vs Thunderbolt.  I found below site that shows the charging distances you can go on USB but not one for Thunderbolt.
http://goughlui.com/2014/10/01/usb-cable-resistance-why-your-phonetablet-might-be-charging-slow/
https://linustechtips.com/topic/748414-cable-charging-distance/
6 minutes ago, iceblade2097 said:
Hello,
https://linustechtips.com/topic/748414-cable-charging-distance/#findComment-9476607
@deXxterlab97
Thank you for the video, however I am more interested on the voltage and amperage drop off rates of different kinds of cables.  For instance does a thunderbolt cable have a different cable make up that allows it to carry more voltage and amps further than a standard usb cable which starts dropping off badly after 1.5 ft.  Or if it still contains the same copper wire make up so the length it can carry the volts/amps is the same.
https://linustechtips.com/topic/748414-cable-charging-distance/#findComment-9507613
