Hello,
Greetings,
I just downloaded OBS to try out streaming for the first time but I cannot stream anything.The problem - I am dropping frames like anything.
I have upto 99% dropped frames sometimes.Why? It's the upload speed,OBS is showing it as 500-1200 kbps and that's just pathetic.
I have a 30 up and 30 down connecetion and it works perfectly fine,just not in OBS.I cannot even stream in 500 bitrate.Idk why isn't obs using my bandwidth properly,maybe you do.
Thanks for your help.
https://linustechtips.com/topic/748225-obs-problems/
3 minutes ago, 4b33r said:
Hello,
Greetings,
How good is your computer
https://linustechtips.com/topic/748225-obs-problems/#findComment-9474263
